LenLindhout
16 -
Reputation
1 NeutralPersonal Information
Occupation
Project Manager
Location
Netherlands
Recent Profile Visitors
GDTF is pain indeed. How ever Wysiwyg implemented it in one update. To bad Vectorworks, one of the original founders of the format isn't able to do that. I'm not using GDTF as it is not that important. The main thing is MVR that I use for most shows. You don't need GDTF for that. On topic: More information in LIR = no.. Sorry but the tech specs at the manufacturers website specs it all. Do your research before you start drawing. This will speed up all the processes of production a lot more. I understand more info but then attach another record with all the fixture information. And call it like that. LFI, Light Fixture Information.
Hey Gijs, Just tried your file. Did connect with me. Dragged (Top/Plan view) your topplate to the truss totem and it snapped in place correctly. Also keeping the 2d information. I just opened your file and it worked. Vwx 2022 sp1.1.
Hi guys, When trying to calculate a truss structure VW crashes.. When I do 'System Check All Objects', BW gives messages for all layher connected fixtures that they are not supported. The message says, solvable system. But when I try 'Calculate Visible' VW crashes. Have tried tearing the set apart that seems to be the only sollution. But is not desirable. This is the message I get.. This is the rig.. I took the circles that are underhung away from the grid because it gave a lot of errors of Fixtures being 'connected to two truss systems' Hope someone knows how to fix this issue.. Thanks, Len
Temporary switch to pan tool with spacebar not working correctly
LenLindhout replied to ronster08's question in Troubleshooting
Also having the same problem. Pan tool not working with space bar. Have tried restarting machine and only start VW. This doesn't solve the problem. VW - 2021 SP4 (B602791) 64bit MacOS - 11.5 Big Sur -
How to change page size of Braceworks Calc report?
LenLindhout replied to LenLindhout's topic in Braceworks
Thanks for the answer, that is unfortunate. Hope this can be changed in future releases? I will submit a feature request for it or is this changing option never gonna happen? Will ask the distributor for now if it's possible to change it.- 4 replies
- braceworks
- report
(and 2 more)
Tagged with:
Hi all, I want to change the page size of my braceworks reports. Currently it's formatting in letter size. But I would like to change it to ISO-A4 size as standard. Can't find it in the BW prefs or any other prefs.. Hope someone can help me! Working with VWX2021 SP3.1 Thanks!
- 4 replies
- braceworks
- report
(and 2 more)
Tagged with:
Schematic View 3D Rotating (Booms)
LenLindhout replied to Daniel B. Chapman's topic in Entertainment
Mmm the fact that you can't convert to Hanging Position is a bummer.. As I always convert for auto naming fixture position. And making labels fast and so.. There are some other issues as well but that's for an other topic. -
Hi there, I needed to export a A0 papersize drawing with rendering fast. So I turned to Cloud Services. But I got a major error on the exported file. I think this has something to do with the difference how lighting symbol rotation is handled between vwx19 and vwx20. This rearranged all my Label Legends. So a lot is unreadable or confusing now. But when I render the same viewport on my computer it gives the correct output. Having read some of the other articles about the 2d/3d label legend differences between vwx19 and vwx20. I came to the conclusion that this may be related. Below are 2 examples. A screen capture of the output from cloud render A screen capture of the output from my laptop. I understand that you want people to switch as fast as possible so you don't have to service multiple platforms but this is just anoying. @klinzey @BSeigel can you guys shed some light on this?
- cloud services
- rendering
(and 2 more)
Tagged with:
Spotlight numbering: one more increment option
LenLindhout replied to Sebastiaan's question in Wishlist - Feature and Content Requests
Hello, Wondering if this feature is somewhere on the list of additions to VWX. Would be a great feature. Now I have to do double work a lot of the time. @klinzey@Yordan Kostadinov can you maybe give a comment on that? Hope to hear something! Thanks! Len -
Spotlight instrument focus
LenLindhout replied to Walter Lutzu's question in Wishlist - Feature and Content Requests
As sebastiaan said! Sliders would be lovely! -
Open Beta Program
LenLindhout replied to Kevin McAllister's question in Wishlist - Feature and Content Requests
Fourth bump! -
[3D Label Legend] Leader Lines
LenLindhout replied to Charlie Winter's question in Wishlist - Feature and Content Requests
Class out would be good and/or maybe a checkbox to switch it on/off? -
Hi there, is someone looking at this? This would be a small but great improvement for v2020 SP1.. Hope this will be implemented soon! -
That would definatly be a great update! That would also work for dmx adressesing I presume??
