Kevin McAllister
    5,224
Posts posted by Kevin McAllister
  1. 4 hours ago, WhoCanDo said:
    Yes, but I couldn't "Closed" it. The Close button would not stay ticked even though it was not greyed.
    The loft created multiple Nurbs and grouped them. It did not merge them into one solid/surface as I was expecting.
    It's the Create Solid checkbox that creates a solid object, not the Closed checkbox. Your curves also need to be going in the same direction.
    Kevin
    • Like 2
  2. It looks like part of your object (a symbol within a symbol) was not designed to be rotated in 3d. The plan view of one of the elements is out of sync with its 3d view. Note that all of the various 2d views within a symbol are user generated. If it's a stage lighting setup there are specific methods to present instruments hung on booms.
    Kevin
    • Like 2
  3. Hello,
    I just got notified and updated to Vectorworks 2024 Update 5. When I started up Vectorworks after the update none of the tools from the tool palettes work. I can select them, but they won't draw, navigate or work in the drawing (both new and existing). The menu commands work fine as do the contextual menus. Its like the tools system is down.
    What's the recommended troubleshooting for this? I've done a restart etc.. Do I need to do a reinstall? Are others having this issue?
    Kevin
    • Sad 1
  4. 8 hours ago, Benson Shaw said:
    Draw a layer plane rectangle. Objects from Shapes. Creates 4 walls, but one corner is not joined.
    I get the same result here - an unjoined corner. It's the same corner that would be open if you converted the rectangle to a NURBS curve.
    Noting that Benson's signature says Update 4 and Tom's says Update 5. I'm using Update 4.1.
    Kevin
    Edit> I updated to Update 5 to test this and now none of my tools work, sigh 😔
    • Like 2
  5. 1 minute ago, Kevin McAllister said:
    What OS and Vectorworks version are you using? It looks like a bug. I'm on a Mac (current versions of both) and don't see the same behaviour. The only difference I can see is you've dismissed the interactive scaling warning dialog (see attached).
    Kevin
    Actually if you change modes while the dragger is set to Re-position mode it happens for me too. Move it off reposition mode and it resets (graphic attached. reposition mode is the one with the arrow, move it to the other one). Definitely a bug.
    Kevin
  6. 17 hours ago, EAlexander said:
    I just make a dedicated layer and drop all my details on there as symbols.  They appear around the drawing as needed, but I viewport them from a sperate independent layer where things never move.  Since they are symbols, I can update them anywhere and they will globally update.
    Also - you need to make a Wishlist request thread for this and let people vote on it if you want the devs to seriously look at it.
    Longstanding wish - sheet layer viewports should be able to look at symbols as an option. @Matt Panzer  it's come up again 😊. Vote here -
    Kevin
    • Like 2
  7. It may well be related to this thread about a bug with symbol creation -
    I know that creating a hanging position makes a symbol so it would be logical it would be affected. Was the hanging position you created originally away from the origin?
    This bug was submitted and confirmed. I don't have a tracking number.
    Kevin
  8. 32 minutes ago, Andy Broomell said:
    If you already have a chain dimension, you can right click on one of the dimensions and choose "Edit Dimension." Then in the pop-up window that looks like the OIP, you can type in a Note and have it affect only the dimension you right clicked on. This approach can also be used for Precision and other properties.
    Oooooh, I just learned something. I needed it only ten minutes ago 😊
    Kevin
