203 -
Posts posted by John Meunier
Is there a way to get the data tag to show secondary units when having it show a dimensional value?
- 1
Great Idea, Love it!
- 1
@twk Yes it is working, thank-you for your solution it works really well!
- 1
@twkVery interesting solution.
Thank-you for taking the time to respond with such depth and detail.
Unfortunately I am unable to get it to work. I have attached a file, perhaps I missed something?
+1 Sketchup 2018 supported required. Please update, so we don't have to ask designers to send older versions.
- 2
Is there the ability to turn other objects visible when editing a symbol inside a viewport annotation?
- 1
On 9/25/2018 at 9:22 AM, Tom Klaber said:
The section seems to be displaying cuts of elements it should not. When I go into Edit Section In Place - those objects are not there - they only show up in the section viewport. Most of them appear to be components of groups of symbols with different classes than their container object - as if the section disregards container objects and breaks everything down when gauging if to display or not.
I have been able to eliminate most of them, but there are these few persistent objects and I can not find the source geometry that is causing them.Is anybody else experiencing this?
Totally experiencing this issue.
It is a brutal bug, working on an apartment building and furniture showing up everywhere it shouldn't.
I'm guessing its related to there new low, med, high feature. When a class is off it should never show up.
My current workaround is to use the Detail Level low and turn off symbols that are inside of unit plan symbols.
I hope VW's fixes this soon.
- 1
On 10/1/2018 at 1:44 PM, Matt Panzer said:
Hi Tom,
I assume you're seeing this in VW 2019?
This is a known issue in 2019 and being looked at.Still happening with SP1 release.
Check out your Navigation Graphics settings. I had issues until I adjusted the settings.
https://forum.vectorworks.net/index.php?/topic/58922-beware-of-navigation-graphics-settings/&page=0#comment-293972
I believe this should be considered a bug, or at min. not desirable behaviour.
Page based symbols do not display correctly when Navigation Graphics is set to Best Compatibility.
This may be is a result of my graphics card, but certain things should always show.
- Create a page based symbol
- when inserted into a section viewport it scales down based on the scale of the viewport it seems.
- when a crop is applied to a viewport the symbol increases in size?
If you print a PDF it displays correctly.
Hi Pat,
I should clarify, by Multi View, I am referring to Multi View Panes where your screen divides into different views.
Black viewports still happening in 2019 😞
Only solution that works for me is to restart vw's.
If your experiencing objects disappearing it maybe due to the Navigation Graphics setting under preferences.
See attached screen recording of the effects between
- Best Performance
- Good Performance and compatibility
- Best compatibility
Bug Alert,
This works with simple object for example draw a rectangle and make it a symbol, the same behaviour will persist.
With a hybrid symbol, open "multiple views panes".
Edit the 2D component of the symbol, the 2D objects disappear.
Also happens when editing a symbol containing symbols, if a symbol is 2D only it will disappear when entering the root symbol with multiple views on.
See Screen recording.
Very frustrating behaviour!!
I think this might be a bug. Space area in a database does not return the expected value in 2019.
@Vasil Kitanov Thank-you for looking at this, perhaps VW's in the future can provide more information with their pop up, with reasons why its not supported.
Any one having issues importing some revit files? I get a dialog with version not supported. Trying to import some lights from Selux.
http://www.selux.us/en/resources/3drevit-downloads.html
Bump, curious if this is corrected.
I'm running into issues with exported fbx files from VW2018.
Thank you guys.
Updated the object to add bends to go around band boards and brick/cultured stone at the bottom.
I'm not sure why, any insight would be great, when adjusting the variables in 3D view the object 'jumps' around on the screen.
We have the same problem when importing a pdf from the server. When a PDF is on the desktop it comes in with no problem.
A simple downspout object for use.
When deleting a window or door style to have the ability to replace it with another style similar to when you delete a symbol.
- 2
Data Tag - Worksheet Database filter by Style?
in General Discussion
Posted
You can create a database of "Data Tags" but it can't seem to filter by style, or display the style being used.
Any Ideas? Optimally I want to create a database of all data tags used in a file with a certain name and call up the parameters to check their values.
