Content Count
183 -
Calendar
Everything posted by John Meunier
Position: full time, Monday to Friday 8AM to 4:30 pm. Looking for Vectorworks user looking for fulltime employment, prefferable coming into the office but will consider remote employment. Thomas Drafting Inc. is a small, Mission-based company. We work in architectural drafting & design, mainly Multi-Family, Apartments and single-family projects. Working alongside other architectural firms, developers, and homeowners. Requirements: Experience in the residential market Experience in Vectorworks a must. We do not use Autocad. Registration with the AIBC, or ability to register an asset Skills: Working knowledge of the current BC Building Code Experience with 3D PLA printing Ability to prepare complete BP document packages Ability to prepare complete DP document package Project management experience. Ability to coordinate with consultants ie Structural, landscape, Electrical, Mechanical, Civil Review and critique preliminary and completed plans from other members of the design team Proficient verbal and written communication skills in English. If interested in working from our office, please submit through our website application, Application Form: https://www.thomasdrafting.ca/contact/careers/ Thank-you
Data Tags - Call up Windows/Doors in Elevation
John Meunier replied to John Meunier's topic in General Discussion
@markdd Your right, but they do not work when the layers are referenced into a new project using Layer Reference.- 2 replies
- data tags
- feature request
(and 1 more)
Tagged with:
Vectorworks Graphics Sync (VGS) API
John Meunier replied to Kevin McAllister's topic in General Discussion
Hmm, This technology sounds like a direct VR link could be in the future? Sending the workspace to a headset, even allowing basic editing or texturing in VR. -
Would be great if Data Tags could be used in annotations for elevations and link to the windows and doors to call them up in Elevation when the project layers are referenced.
- 2 replies
- data tags
- feature request
(and 1 more)
Tagged with:
Data Tag - Worksheet Database filter by Style?
Hi @Nikolay Zhelyazkov Yes, That's the setting I missed thank-you. -
The stake objects for the DTM allows users to choose which units to display, this functionality should be added to the elevation benchmark tool. (And Record Formats & Data Tags) Attached is a screenshot or of the current elevation benchmark, and a portion of the Stake Object showing the ability to choose units.
- 1 reply
- 5
- units
- elevation benchmark
(and 1 more)
Tagged with:
You can create a database of "Data Tags" but it can't seem to filter by style, or display the style being used. Any Ideas? Optimally I want to create a database of all data tags used in a file with a certain name and call up the parameters to check their values.
Is there a way to get the data tag to show secondary units when having it show a dimensional value?
Great Idea, Love it!
@twk Yes it is working, thank-you for your solution it works really well!
@twkVery interesting solution. Thank-you for taking the time to respond with such depth and detail. Unfortunately I am unable to get it to work. I have attached a file, perhaps I missed something? ALLCAPSPython.vwx
Is there the ability to make a VW 2019 file ALL CAPS? Including databases and text styles. So far my workaround has been to manually type in CAPS, but the database header has got me stumped. I must be missing something. Any help is appreciated. Thank you
Import SketchUp 2018
John Meunier replied to ericjhberg's question in Wishlist - Feature and Content Requests
+1 Sketchup 2018 supported required. Please update, so we don't have to ask designers to send older versions. -
Is there the ability to turn other objects visible when editing a symbol inside a viewport annotation?
- 1 reply
- 1
Totally experiencing this issue. It is a brutal bug, working on an apartment building and furniture showing up everywhere it shouldn't. I'm guessing its related to there new low, med, high feature. When a class is off it should never show up. My current workaround is to use the Detail Level low and turn off symbols that are inside of unit plan symbols. I hope VW's fixes this soon.
Still happening with SP1 release.
Section Viewports. Odd behaviour
John Meunier replied to Andrew Davies's question in Troubleshooting
Check out your Navigation Graphics settings. I had issues until I adjusted the settings. https://forum.vectorworks.net/index.php?/topic/58922-beware-of-navigation-graphics-settings/&page=0#comment-293972 -
I believe this should be considered a bug, or at min. not desirable behaviour. Page based symbols do not display correctly when Navigation Graphics is set to Best Compatibility. This may be is a result of my graphics card, but certain things should always show. - Create a page based symbol - when inserted into a section viewport it scales down based on the scale of the viewport it seems. - when a crop is applied to a viewport the symbol increases in size? If you print a PDF it displays correctly. Page Based Symbol.vwx
Hi Pat, I should clarify, by Multi View, I am referring to Multi View Panes where your screen divides into different views.
- 2 replies
- symbols
- multiple views
(and 2 more)
Tagged with:
Black viewports still happening in 2019 😞 Only solution that works for me is to restart vw's.
If your experiencing objects disappearing it maybe due to the Navigation Graphics setting under preferences. See attached screen recording of the effects between - Best Performance - Good Performance and compatibility - Best compatibility Navigation Graphics.mov
Bug Alert, This works with simple object for example draw a rectangle and make it a symbol, the same behaviour will persist. With a hybrid symbol, open "multiple views panes". Edit the 2D component of the symbol, the 2D objects disappear. Also happens when editing a symbol containing symbols, if a symbol is 2D only it will disappear when entering the root symbol with multiple views on. See Screen recording. Very frustrating behaviour!! Screen Symbol.mov
- 2 replies
- symbols
- multiple views
(and 2 more)
Tagged with:
Database 'Space'.'Area' Function different in 2019
John Meunier posted a topic in General Discussion
I think this might be a bug. Space area in a database does not return the expected value in 2019. Space Issue 2018.vwx Space Issue 2019.vwx -
I can't find the syntax to reference the Layer Description in a worksheet database listing the layers in the file. Anybody know where to find this or what it is?
Import Revit File - Version Not supported
@Vasil Kitanov Thank-you for looking at this, perhaps VW's in the future can provide more information with their pop up, with reasons why its not supported.
