remarkr Posted November 12, 2001 Share Posted November 12, 2001 I am trying to render a transparency using the Render Bitmap tool but it comes out as a solid. The transparency works fine when I use Final Quality RW. Any suggestions? Quote Link to comment
MikeB Posted November 13, 2001 Share Posted November 13, 2001 Huh, I just tried it and your right. I don't use the Render Bitmap tool much and I thought that it was tied to the custom renderworks options, but even when I set the custom options to use transparency it dosen't. Not with the render Bitmap tool or the custom Renderworks. I think its a bug. Quote Link to comment
remarkr Posted November 13, 2001 Author Share Posted November 13, 2001 Mike, thanks for your reply. it didn't even occure to me that there was a "Use transparency" option in the prefrences. I don't know how may times I've opend that box & never noticed it. I went in and turned it on and it worked for me. So, as far it not working for you, maybe the transparency needs to be set higher on the shader your using. Thanks again. Quote Link to comment
MikeB Posted November 13, 2001 Share Posted November 13, 2001 Are you useing 9,0,1 or 9,5,0b7 I'm using the beta Quote Link to comment
remarkr Posted November 13, 2001 Author Share Posted November 13, 2001 i'm using 9.0.1 on a MAC Quote Link to comment
jnr Posted November 20, 2001 Share Posted November 20, 2001 See the message posted by me above. The lack of transparency is happening to me as well. This is with all the boxes checked. Final renderworks renders the image correctly. It appears to be a bug. Anybody from NNA want to weigh in? Quote Link to comment
