Jack A Posted February 25, 2006 Share Posted February 25, 2006 Is it possilbe to assign a class color and thickness to a wall that is not "unstyled." Quote Link to comment
CipesDesign Posted February 25, 2006 Share Posted February 25, 2006 Your question contains a double negative, but I think the answer is yes-yes. To do what you ask, go into the wall pref's and create (or modify) a new wall style. Click on the "edit" button and then choose "use class attributes". Now create a class, set the attributes as you like, and be sure to check "use at creation". Now select the wall(s) and place it into the class. As an extension, you can also check "use textures at creation" and then go in and set the texture(s) you want for the left, center & right side of the wall(s). As an extra added bonus, you might check out the VP class override feature which allows you to change class attributes in a specific VP. HTH's :-) Quote Link to comment
Jack A Posted February 25, 2006 Author Share Posted February 25, 2006 I didn't know that this was an English grammar board as well ... though that was an intentional double negative. When I click on the 'edit' button, I see options to set the thickness, color, etc, but I do not see any options to use class style. I am using VW12 Architect - if that makes any difference. Quote Link to comment
Spunkmeyer Posted February 25, 2006 Share Posted February 25, 2006 It's available in 12.0.1, but not 12.0.0 - have you updated yet? Quote Link to comment
CipesDesign Posted February 25, 2006 Share Posted February 25, 2006 Oops. I need to go edit my profile again... :-) Quote Link to comment
Jack A Posted February 26, 2006 Author Share Posted February 26, 2006 That fixed it ... thanks! Quote Link to comment
carpalmer Posted March 1, 2006 Share Posted March 1, 2006 Yes, but cannot asign class to different wall components. How do you go from a structural drawing wall (no finishes) to an architectural wall (with finishes)using the SAME wall element as VW intends us to structure the drawing (ie: one design layer from where all plans originate via VP's)??? Quote Link to comment
