Diana A Posted May 5, 2022 Share Posted May 5, 2022 Hi I'm only getting black and white when drawing, although it's not ticked doc prefs, or VW prefs. Any ideas? Mant thanks, darnold3 diana@dianaarnolddesign.co.uk Quote Link to comment
0 Pat Stanford Posted May 5, 2022 Share Posted May 5, 2022 If you create a new blank drawing can you draw in it in color? Many things could cause Black and White drawing. I am assuming you mean on screen, not in a printout. Design Layers or Viewports on Sheet Layers? Are you certain you did not accidentally click the Black and White Only Quick Pref in the Mode bar? Do you use Data Visualizations and accidentally got one turned on? Are you objects set to use Class Attributes and the classes are set to B/W? Quote Link to comment
Diana A
Hi
Mant thanks,
darnold3
1 answer to this question
