Vectorworks, Inc Employee Robert Anderson Posted November 12, 2005 Vectorworks, Inc Employee Share Posted November 12, 2005 What do you mean by trapezoid windows? Do you mean sloped-top windows? Quote Link to comment
michael s Posted November 13, 2005 Author Share Posted November 13, 2005 How can I create trapezoid windows, and show them in 3D elevations drawings? When I use the "rotate 3D" procedure the 3D walls also rotates. Quote Link to comment
CipesDesign Posted November 13, 2005 Share Posted November 13, 2005 Trap windows are tricky. As far as I know there is no simple way to do it, but here are a couple options. 1) Create a window with close to zero actual height, but with a "sloped" transom of the desired height. 2) You can "subtract solids" from the wall. So you would create an extruded tapazodial form that would cut out a portion of the walls. This means the wall will lose its editability (as a wall). Quote Link to comment
michael s Posted November 17, 2005 Author Share Posted November 17, 2005 by trapezoid - similar to parallelogram. the top & bottom is the same slope, say as a roof, and the two sides are plumb. Quote Link to comment
Kevin Posted November 17, 2005 Share Posted November 17, 2005 I have constructed windows from solids. For circular windows I have had to do this. It takes time, but it can be done. BTW, I think NNA forces us to do this from time to time so that we will appreciate how wonderful and easy the window PIO is. Quote Link to comment
