Ellison1079 Posted September 23, 2005 Share Posted September 23, 2005 I'm trying to reference files for 5 separate buildings into one file - the problem is that the layers in each of the 5 buildings have the same names, so once I reference the first building, it won't allow any others to be referenced in, telling me that the layer names are already being used. Is there any way (other than re-naming each building's layers differently) to reference all of these files? Other question - when referencing, I keep getting a box that says "Rename the class definition named door". I've had to do close to twenty of them, and keep having to give them different names. What's this about? What's a class definition? Quote Link to comment
mike m oz Posted September 24, 2005 Share Posted September 24, 2005 Been there. The only way to do it is to rename the layers in the source files. What I did was add the Lot No. in front of each layer name of the source files. Quote Link to comment
Jonathan Pickup Posted September 24, 2005 Share Posted September 24, 2005 there are some particular do?s and don?ts when using WGR, and you?ve discoverd a few of them. Layer names have to be unique, so as mike says, you have to name each layer differently. You are not allowed a class called door and an object called door. Change the class name... another thing to watch out for are symbols with the same name. Two file could have the same symbol name, but they could be different things. They have to have different symbol names. In my VectorWorks Architect Tutorial Manual I outlined many of these do?s and don?ts, to help people understand the process before they start drawing. Quote Link to comment
