TBrown Posted August 26, 2005 Share Posted August 26, 2005 I am placing Door Numbers using the ID label Tool, and I am working on a metric drawing at 1:200. The problem I am having is that the ID Labels are really quite large in the scheme of things. The manual says that they can be scaled up or down by using the "marker scale factor" in the Object Info Palette, but this seems to have no effect on the size at all. Anyone know of a way to do this? I need to shrink the ID's by half. Quote Link to comment
Robert Anderson Posted August 26, 2005 Share Posted August 26, 2005 What version are you using, Trevor? Quote Link to comment
TBrown Posted August 26, 2005 Author Share Posted August 26, 2005 I using VW Architect version 11.5.0, running on a Mac G5 Dual 2.5 GHz with OSX 10.4.2. Quote Link to comment
islandmon Posted August 27, 2005 Share Posted August 27, 2005 T.A.B.... the 'marker scale factor' seems to be the solution but sometimes requires that you tab or return out of the field in order to register the change. Quote Link to comment
