Andrew Mac Posted August 3, 2005 Share Posted August 3, 2005 I am trying to add a dormer from a symbol to a roof face. I know you can do this if you make rood from creat roof command- but how about just from a roof face command? Quote Link to comment
CipesDesign Posted August 3, 2005 Share Posted August 3, 2005 If I remeber correctly you can only add a "dormer object" to a "roof", not to a "roof face". My personal preference though is to bypass the dormer object (as I have never found it to be very easy or intuitive to use). I usually just add walls where they need to be, reshape them either with the "fit walls to roof" command or the 3d reshpae tool, and then add a roof. To use the "dormer object" you need to start with a roof object and then insert (drag) a window symbol from the resource browser onto it. Then comes the fun (not) part of trying to make it behave!!! Good luck... [ 08-03-2005, 10:49 AM: Message edited by: CipesDesign ] Quote Link to comment
Andrew Mac Posted August 3, 2005 Author Share Posted August 3, 2005 Thanks very much- that's what I thought. Just add rhe dormer roof the walls and then add the window. Thank you Quote Link to comment
