Ramon PG Posted August 1, 2005 Share Posted August 1, 2005 FYI (excuses for those who already know this) If, after setting the Model, you change layer names like Mod-Floor-1 to Floor-1 (like I id) going back to model setup to tweak anything will result in all settings appearing as zero. Even if the Model looks OK. You can either change the layer names back or set the layer height thru the Layer Setup window. And stop from wasting a couple of hours trying to figure it out. Using 11.5.1 Mac OS 10.3.8 Quote Link to comment
islandmon Posted August 2, 2005 Share Posted August 2, 2005 Now... that's not supposed to happen cus the Layer name also has a Layer ID# and changing the name does not change the LayerID#... period. Layer attributes are connected via API to the LayerID# not the associated LayerNameString. Perhaps if you update OSX to 10.3.9 this issue will be resolved in your case. Quote Link to comment
Ramon PG Posted August 3, 2005 Author Share Posted August 3, 2005 All I can tell you is that reverting the layer names to what appears in the model setup window will show the heights again. I am upgrading to 10.3.9 to see what happens. It's not a big deal if you figure it out, but Tech Support didn't have a clue... Quote Link to comment
