Andrew Mac Posted July 9, 2005 Share Posted July 9, 2005 I am hoping that someone can tell me if I can add color to a hatch. I am using a pc with VW 11.5 Quote Link to comment
CipesDesign Posted July 9, 2005 Share Posted July 9, 2005 Yes you can. Here's how: 1) Apply a hatch to an object 2) With object selected, in the ATTRIBUTES palette, click on the name of the hatch (which should be there, it's the second pulldown from the top) and the pulldown will open. Scroll down to "Hatch...". 3) Now you should have a dialog called "Document Hatches". Make sure the correct hatch is highlighted and click on "edit". 4) Now you should have a dialog called "Edit Hatch". In this dialog you can change the color/weight of any of the line segments and 5) you can add a background fill to the hatch, and choose the color of that fill. Hope that helps... Quote Link to comment
Andrew Mac Posted July 18, 2005 Author Share Posted July 18, 2005 Thank you very much!!! Quote Link to comment
