Ben3B Posted February 3, 2022 Share Posted February 3, 2022 Hello in the manuel I can read : https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Structure/Setting_class_properties.htm Quote Description/Tags Description: Enter additional information about the class. The description displays as a screen tip when you hover over the class name in the Organization dialog box, Navigation palette, or (on Mac only) the Classes list from the View bar. Descriptions also display in the New Class dialog box, so that you can see descriptions of classes before you import them. is a way to view the class description (for example) in the navigation pane ? activate a column maybe ? Quote Link to comment
Pat Stanford Posted February 3, 2022 Share Posted February 3, 2022 I don't believe there is currently a way to see the description in the Navigation Palette. 1 Quote Link to comment
Pat Stanford Posted February 3, 2022 Share Posted February 3, 2022 If you hover over the name of the layer or class the description will show up in the tool tips. But you have to hover long enough on each one to show. Quote Link to comment
Ben3B Posted February 4, 2022 Author Share Posted February 4, 2022 12 hours ago, Pat Stanford said: If you hover over the name of the layer or class the description will show up in the tool tips. But you have to hover long enough on each one to show. Yes true, as it is written in the manuel, but it's not "quick" enough ... a column would be better I think 🙂 I'll put the link to that post in the request for path column 😉 https://forum.vectorworks.net/index.php?/topic/92007-file-path-in-dedicated-column-in-ressource-manager/#comment-418886 Quote Link to comment
