jmccain8 Posted January 28, 2022 Share Posted January 28, 2022 I'm wondering if there is a simple way to hide the parts of plants that extend beyond a fence or wall in 2D plans. In some circumstances, it makes sense to place plants close to walls, and depending on the type of plant, the growth will not extend beyond the surface of the wall (or fence), so it would be easier to understand a 2D plan if I could clip the part or the symbols beyond the wall. In the example below, I would like the 2D symbols for these shrubs and coniferous trees to stop along the inside of that dark fence. Thanks for any tips you can provide! James Quote Link to comment
Jeff Prince Posted January 29, 2022 Share Posted January 29, 2022 You could mask the trees with a polygon in the annotation space or design layer, that’s probably fastest. Stacked viewports with your tree design layer only showing on one of them, draw order that to the top, clip the viewport to suit, slightly more effort. Create custom symbols for this condition…insane waste of time. Print your plans to PDF, one for the plan, the other for the trees, modify in photo editor… insane waste of time unless it’s a final version of an illustrative plan. Live with it as landscape architects have done for decades, insane savings of time 😉 Quote Link to comment
jmccain8 Posted January 29, 2022 Author Share Posted January 29, 2022 Thanks for these rated ideas, Jeff! If I mask the section beyond the fence with a polygon, wouldn't it have to be filled and at 100% opacity? I'd rather not fill the entire area beyond the fence. Or have I misunderstood you? I'm still somewhat of a novice 🤪 Quote Link to comment
Jeff Prince Posted January 29, 2022 Share Posted January 29, 2022 26 minutes ago, jmccain8 said: Thanks for these rated ideas, Jeff! If I mask the section beyond the fence with a polygon, wouldn't it have to be filled and at 100% opacity? I'd rather not fill the entire area beyond the fence. Or have I misunderstood you? I'm still somewhat of a novice 🤪 Yes, you will need polys with no pen, but 100% fill to mask them out. If you place features on different design layers you can change the stacking order of the layers to achieve the look you want. by placing your tree masks on a separate design layer, you can quickly adjust all of their positions in the stack at once as compared to using a “draw order methodology” to achieve the same. 1 Quote Link to comment
jmccain8 Posted January 29, 2022 Author Share Posted January 29, 2022 Thanks, Jeff! I appreciate your help. 1 Quote Link to comment
