ssheldon Posted May 4, 2005 Share Posted May 4, 2005 Is anyone actively using the keynoting / database function on architectural working drawings Quote Link to comment
Jonathan Pickup Posted May 4, 2005 Share Posted May 4, 2005 yes, I use it mainly on demolition drawings. Quote Link to comment
Travis Posted May 4, 2005 Share Posted May 4, 2005 We use it extensively. I personally probably place a dozen or more keynotes most days. We've had some problems when using a central database. . .sometimes Keynotes (and General Notes as well) seem to "forget" the path to the remote file. You might find yourself having to re-connect using the Browse button. Several times the central file has become somehow corrupted and we've thrown it away. . .to be reconstructed from drawings (the text is actually stored with the drawing) that used the common database. For some reason, this last issue has not recurred since we went through and edited our common databases from all caps to upper/lower case using Word. I can't for the life of me figure out what difference either using Word or changing the case would have made, but things have been much more stable the last several weeks. Good luck, Quote Link to comment
