Delmer Posted May 2, 2005 Share Posted May 2, 2005 Double-check that the thickness of the cavity line in the wall preferences isn't set to 0. The pen may still show solid & black, but weight may be the problem. Quote Link to comment
John Oualline Posted May 2, 2005 Author Share Posted May 2, 2005 They were set to default and I thought that default would have a line width - changing them to .03mm did the trick. Thanks. Quote Link to comment
John Oualline Posted May 3, 2005 Author Share Posted May 3, 2005 All of a sudden my cavity lines are not showing in new walls - they are drawn but when I click to end a segment, the wall outline is all that remains. I've checked to make sure document setup scale is set to show cavities; I've checked Classes to make sure the wall class is visible and the pen is solid and black; I've checked in Edit Wall type to verify that cavity lines are solid and black. Yet after it is drawn, the Object info shows all cavity lines set to invisible. Help? Quote Link to comment
