John Oualline
28 -
Never
Reputation
0 NeutralPersonal Information
Occupation
Architect
Location
Santa Fe, NM
Does anybody know of a commercially available keynotes database for Architect (residential or light construction) similar to the new Autodesk based on Masterspec notes database?
I'm suddenly getting the following error: "Error: _3246 _3249 - Index outside array limits." and I am unable to setup viewports through the setup command - is there a way to fix this without damaging my file?
1. Can you delete a "sheet" from the Issue Manager? - it is tracking sheets that I have deleted out of the file. Suggestion: Add a button on the Issue Manager to Delete. 2. Can you re-order the sheets in the Issue Manager? Suggestion: Add a Send Backward, Send to Back, Send to Front, and Send Forward command. Better, have the script reorder based on the Data file for that sheet.
Thanks!
Can you edit ConDoc sheet symbols? They don't seem to be in the Data_Sheets file.
I'm on VW 11.1 using a Windows based system.
I'm a newbe, so bear with me please. I've read about title borders, sheet symbols, et al until I think I've read them all. That said, where did the Sheet-Common layer come from and what is it's best use? I didn't set it up, so I assume it is a default layer? Sheet borders and title blocks would be the logical use for it, but placing the sheet symbol on it doesn't work with the Issue Manager on separate sheets. So I can't see what else would be common, unless it is a sheet weasel clause or "Not for Construction" stamp, etc. Any suggestions?
I can't find the ConDoc D symbol to edit. A - The Document Setup allows for ConDoc D to sleect. Once it is on the sheet layer, it has no edit behavior. I can mass change the font in Text, but I cannot format the text fields to bold, make larger, etc. B - The Border symbol tool allows for ConDoc D selection, but again there is no edit behavior once on the sheet. C - For some reason, the sheet library objects I've placed in my Favorites does not have ConDoc sheet available. Help?
I've run Document Setup to select ConDoc D as my drawing border. I'd like to now format the ConDoc D border symbol to format text attributes to different font, bold, etc (I will use the Issue Manager to edit the text). I can't find the ConDoc symbols in the Resource Browser to edit the symbol, nor is it in my file's resources. Doubleclicking on the sheet border in sheet view just gives me the "object has no edit values" notice. Help?
Thanks - I;ll try it again - must have missed the double-click on the line or something. Standby...
I've run Document Setup and selected ConDoc D. I now would like to edit format the Company Name and other certain other Issue Manager object info text to bold, different font, stc. Is there a way to change formatting on the sheets?
As a newby, I have somehow created a minor problem: views and sheets don't aline. For example, I go to Mod Roof and the sheet outline location is up and to the right. I can drag the sheet to aline, but what did I do to create this mess?
OK, I gave up after the 5,000th crash yesterday. I uninstalled 11.05(build) and reinstalled 11.01 - I'll wait for version 12 and hope they have it worked out. Hopefully, 11.01 is more stable.
All of a sudden my cavity lines are not showing in new walls - they are drawn but when I click to end a segment, the wall outline is all that remains. I've checked to make sure document setup scale is set to show cavities; I've checked Classes to make sure the wall class is visible and the pen is solid and black; I've checked in Edit Wall type to verify that cavity lines are solid and black. Yet after it is drawn, the Object info shows all cavity lines set to invisible. Help?
