John Windswept Design Posted February 3, 2005 Share Posted February 3, 2005 GREAT!!! Thanks Peter I have another question. I'm always going to class visibilities picking all the classes and then making them visible. I do this because I always seem to insert something into classes that are invisible. I tried the script automation and failed. Any Ideas? Quote Link to comment
CipesDesign Posted February 3, 2005 Share Posted February 3, 2005 Which scrpit? Something you wrote? Quote Link to comment
John Windswept Design Posted February 3, 2005 Author Share Posted February 3, 2005 No not me. Is there not a way of creating a script for a series of commands re: pick all the classes and then making them visible. Regards John T Quote Link to comment
G_Hannigan Posted February 4, 2005 Share Posted February 4, 2005 I've done this using Saved Views. You can set Layer & Class properties and save them as a View. When you return to a Saved View the stored Layer & Class properties are restored. As metioned in another thread, these functions should be part of the Layer & Class dialogue boxes. George Quote Link to comment
John Windswept Design Posted February 4, 2005 Author Share Posted February 4, 2005 I'm a little confused with dimension class. If I imput a dimension and it automatically goes on dimension class should it not also take on the line wieghts and color of the dimension class. Mine seems to take on the character of my attribute palette. How can I have my dimensions always come out STD? Also is there a way to change the line wieght of the dimension line extensions? Mine doesn't seem to change. Also I can't seem to find a toggle to automatically keep my precision to 1/2". I after I input my dimension I can change it but I would like them never to show 1/8" inch. Regards John T Quote Link to comment
CipesDesign Posted February 4, 2005 Share Posted February 4, 2005 John, 1) Open the CLASS dialog and double click on the dim's class. Check to make sure that "use at creation" is selected. If not, your dim's (and any other class for that matter) will take on whatever you have set as the default at the time. 2)(I think this is what you meant) Go FILE>PREFERENCES>DOCUMENT PREFERENCES and click on the DIM"S tab. You can change the slash weight here. 3) Go to PAGE>UNITS... Here you will find three items in the scroll down, each of which can be user set. Hope that helps :-) Quote Link to comment
G-Pang Posted February 4, 2005 Share Posted February 4, 2005 Try this... Procedure DeActivateClass; VAR x, y: Real; h: Handle; active, Name:STRING; message :integer; Result:BOOLEAN; BEGIN repeat begin active:=Activeclass; GetPt(x,y); h:=PickObject(x,y); setSelect(h); if h<>nil then begin Name:=GetClass(h); if (GetClass(h)=active) then SysBeep; if (GetClass(h)<>active) then begin HideClass(Name); end; setDSelect(h); end; end; ReDraw; until h=nil; END; Run(DeActivateClass); Quote Link to comment
John Windswept Design Posted February 4, 2005 Author Share Posted February 4, 2005 To run this just create a txt file and put the data in then run vectorscript? What exactly does this dooo? j Quote Link to comment
G-Pang Posted February 5, 2005 Share Posted February 5, 2005 That is a basic classes controlling script. Just modify it a bit to suit your need. G-Pang Quote Link to comment
John Windswept Design Posted February 5, 2005 Author Share Posted February 5, 2005 Yiks!! whats that? Quote Link to comment
CipesDesign Posted February 5, 2005 Share Posted February 5, 2005 vector script [ 02-04-2005, 12:46 PM: Message edited by: CipesDesign ] Quote Link to comment
