Seena Hassouna Posted January 13, 2005 Share Posted January 13, 2005 So, I have a building with 11 7/8" TJI's as the roof members but we want to use 2x8 outlookers as the eave. How do you suggest doing this. Using chain extrude or making the roof thinner. I'm a bit concerned about the latter cuz of bearing height accuracy. Thanks, Seena Quote Link to comment
CipesDesign Posted January 13, 2005 Share Posted January 13, 2005 Hi Seena, For me it would depend on whether I was doing design docs (eg for presentation) or WD's. For designing it is pretty fast to use two roofs. The first one would be as thick as the 11 7/8 plus your sheathing and would have zero overhang. Then I would duplicate that in place, change the thickness to 7 1/4 plus sheathing, go to an elev. view and move it up to be exactly even with the top of the first roof, and then add overhangs. For WD's I would probablr either just draw it in section (2d) or I would draw the profile of each member and then extrude to 1 1/2", go to a top view and duplicate every 24" (or whatever) then create a "skin" which could be a very thin roof or just another extrude. Quote Link to comment
Seena Hassouna Posted January 13, 2005 Author Share Posted January 13, 2005 Thanks Peter, I'll probably use your first suggestion. I was hoping there was a cleaner way. Seena Quote Link to comment
