LarryAZ Posted August 8, 2005 Share Posted August 8, 2005 Has anyone mastered the property line tool? It works fine with straight lines but I'm really frustrated with the arcs. The help file doesn't really give any example. Does anyone have a step by step example of how it works. The survey example I have to work with has delta angle in d, m, & s, radius, and length. Thanks for the help. Quote Link to comment
Jonathan Pickup Posted August 8, 2005 Share Posted August 8, 2005 Larry, can you email me directly later. I might be able to find a step by step that might help. My architect manual has a property line with a curve... Quote Link to comment
LarryAZ Posted August 19, 2005 Author Share Posted August 19, 2005 I still need to get this to work. Robert is more documentation available for this tool. Right now I'm drawing all the straight lines and fudging the arcs. Help... please... Quote Link to comment
stmlandplan Posted August 23, 2005 Share Posted August 23, 2005 Larry, I had the same problem with the program asking for backtangents and what I needed was forward tangents. I couldn't get a suitable answer from VW so we constructed the geometry and found that if you did a manual conversion, by adding (or subtracting?) 90d its pretty simple to obtain the answer. Its easier to switch over to radian than degrees (or was it the other way around. Hope this isn't too cionfusing. Oh by the way you can't just input any value into the pop-up (which is the intuitive way). Quote Link to comment
