Section not showing material
Vectorworks.vwxhi everybody,
i have a weird problem that when i create a section it does not show material. I attached the file
so this is what i have done so far to try to fix it
oip > background render settings > material being checked (double checked it and unchecked it with nothing working)
change from open gl to renderworks (not showing it)
went to material in the wall style and changed it to all sorts of settings
Go the the Advance Section Properties dialog (via the Object Info palette button) and try these settings:
BTW:  I noticed the window in the wall to the left in the section is not inserted into the wall causing their geometry to overlap each other.
thank you!
works perfectly now
