  • 2
FBernardo
Stair Settings button "make all settings by class"
Hi all,
As per the title is it possible to add a button to make "all Settings by Class" (as it's added in the Wall style), so when we want to change them to match the class settings it doesn't have to be one by one.
Stair Settings:
Wall Settings:
1 answer to this question
Click on the 'Set Class Style' button to make all the Stair attributes by class.
What would be advantageous would be the ability to select multiple stair components at once + assign all of them to the same class rather than having to click through them one at a time. I think someone else requested this ability. But the fact is once you've done it once you can save the settings for reuse across other stairs so it's not like you necessarily have to do it every time.
With Wall Styles you still need to assign each component to a class but there you CAN assign classes to multiple components at once + even if each component is in its own class you can do it all from the drop-downs in the components list in the 'Edit Wall Style' dialog so fewer clicks. So yes, be good if Stair tool had same functionality
