DBLD Posted April 26, 2021 Share Posted April 26, 2021 When rendering a still image through Render>Render Still Vision crashes. It outputs the still image but the program crashes. This is a relatively simple scene exported as MVR from Vectorworks. Render quality is very high and resolution is either 1920x1080 or 3840x2160- both crash. I have done plenty of renders before with more complex scenes and haven't had this issue before. Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted April 26, 2021 Vectorworks, Inc Employee Share Posted April 26, 2021 I had gotten a report from an end user not too long ago reporting something similar. I've seen (what seems to be) random crashes with Render Still. One thing that seems to help reduce the number of crashes is ensuring that your Rendered Still uses "<Active Settings>". If you want the still to be higher quality, you may try adjusting your realtime render settings such that "<Active Settings>" for Render Still uses higher quality settings. I hope this helps and we are investigating the issue in more detail internally. Quote Link to comment
