Dan borg
Converting wrapper to object node
Hello,
I'm quite new at marionettes and have tried building a simple network that extrudes a poly line created from a series of arcs. It seems to work fine as a network and also as a wrapped network but when i convert it to an object node it will only create the poly line without extrusion. Any clue on what I'm doing wrong?
Marionettte extrude 210426.pdf
the compose node don't work in your Marionette Object.
I think this part of the node is the cause:
I'll test a workaround tomorrow...
1217002607_Bildschirmfoto2021-04-29um19_10_38.thumb.png.6b389884d20b92a2f9c871719480a13f.png
Sorry, so far I haven't found a workaround.
 I have tried to create one arcpolyline instead compose single Arclines.
