drawing grid bubbles
Mat Caird
Hey, Mat. This is a known bug. If you draw the first segment in the -y direction, the control point that controls the length of the grid lines is misplaced. If when you first draw such a grid line, you then grab the control point (which will be found at your first click entry point) and reshape it, then your line of grid bubbles should behave normally from then on. Sorry for the inconvenience.
HTH, Robert
