Grzegorz Krzemien
Tile filling does not map in slabs
Hello,
I have some problems with Tile fills in my slabs. I tried to create own Tile fillings for my slabs, but they all fail in sections. As I noticed even built-in Tile fills do not work properly - they are moved, not aligned etc. I tried many combinations of settings, but still either I am missing something or it just does not work.
Picture and file in attachment.
Slab test.vwx
I can't open your file because I'm on VW2020 but I would check your 'Edit Tile Settings': do you have 'In Wall' + 'Fit to Wall' enabled? The former rotates the tile to the orientation of the wall/slab/roof component + the latter scales it to match the component's thickness
Yes you're right works fine in the VW2020 file. You need someone else to test it in VW2021. Don't believe I've seen any other posts about this happening in VW2021... Do the tiles work ok on roof components?
