Sam Jones Posted April 3, 2021 Share Posted April 3, 2021 How do I get the symbol name of an accessory that is attached to a light at a given cell index and accessory index? There does not seem to be a parameter to query. Quote Link to comment
Jesse Cogswell Posted April 3, 2021 Share Posted April 3, 2021 I just ran a test using LDevice_GetParamStr(<handle to light>,<cell index>,<accessory index>,'Symbol Name') and was able to successfully get the symbol name of an attached accessory. The LDevice_GetParam series uses the standard Lighting Device parameter names in for the "universalName" listings in the Function Reference, so if you have a list of the Lighting Device parameters handy, you should be able to get all the parameters you need. Quote Link to comment
Sam Jones Posted April 3, 2021 Author Share Posted April 3, 2021 19 minutes ago, Jesse Cogswell said: so if you have a list of the Lighting Device parameters handy, you should be able to get all the parameters you need. Thank you for the pointer. I will try it out, however. Below is the list of LD parameters that I have and no where does the syntax that are using shows up. Where is "cell index", "accessory index", and "Symbol Name". I can use "Symbol Name to get the symbol name of the lighting device that has accessories. Though I haven't tried it yet, I'm confident that your use of ...GetParamStr works, but how did you think to use it in the way that you did, because to me there is not hint about doing that that I can derive from the LD parameter list. Lighting Device Universal Device Type Inst Type Edit Cell Edit Accessory FixtureID Old Inst Type Gobo Data Color Data Color Flag Data Fixture Mode Old Fixture Mode Vision Lit Override Vision Fixture Name GDTF Fixture Name GDTF Fixture Mode GDTF Fixture Type ID GDTF Fixture Custom ID GDTF CIE Color Wattage Purpose Position Unit Number Color Dimmer Absolute Address Channel UniverseAddress Universe DMX Address Num Channels Circuit Number Circuit Name System User Field 1 User Field 2 User Field 3 User Field 4 User Field 5 User Field 6 Voltage Breaker ID Time Cost Frame Size Field Angle Field Angle 2 Beam Angle Beam Angle 2 Weight Template TemplateRot1 Template2 TemplateRot2 Gobo Shift Mark Draw Beam Draw Beam as Solid Use Vertical Beam Show Beam at Fall off distance Lamp Rotation Angle Top Shutter Depth Top Shutter Angle Left Shutter Depth Left Shutter Angle Right Shutter Depth Right Shutter Angle Bottom Shutter Depth Bottom Shutter Angle Light On Lit Fog Brightness Symbol Name Use Legend Legend View 3D Flip 3D Top Bottom Flip 3D Left Right Rotate 3D Legend Flip Front Back Flip Left Right Focus Pan Tilt Throw Distance Rotate3DPosition xRot yRot EnableZRot zRot zRot2D Focus Angle Vertical Focus Angle Horizontal Angle To Face Plane Off Axis Angle ShowData Ganged With Use Active Symbol ControlPoint01X ControlPoint01Y ControlPoint02X ControlPoint02Y ControlPoint03X ControlPoint03Y ControlPoint04X ControlPoint04Y ControlPoint05X ControlPoint05Y ControlPoint06X ControlPoint06Y ControlPoint07X ControlPoint07Y ControlPoint08X ControlPoint08Y X Location Y Location Z Location Do Not Edit Alt-Chan Alt-Dim Alt-Unit Alt-Circ Is New __Version NoExport Lightwright ID RGBColor UID __CommPasteName __LabelHandlesData __LabelHandles3DData __CellsCount __AccessoriesCount Dimension UseGDTFGeometry WeightDouble Edit GDTF Data Quote Link to comment
Jesse Cogswell Posted April 3, 2021 Share Posted April 3, 2021 It's tricky, since there doesn't seem to be a script to get a handle to an attached accessory, but that doesn't matter in this case. The Function Reference continues to be rather dreadful, so it took some trial and error to get the information I needed. The Function Reference doesn't break down the passed variables its looking for the LDevice_GetParam commands, but the description says, "Get parameter of a Lighting Device or attached Accessory by Worksheet Name. Use cell index 0 to operate on the first cell. Use accessory index -1 to access the lighting device parameters." That's not super clear, but what I got from it is that accessoryIndex is 0-based with -1 then being used to get the parameter from the parent Lighting Device. Worksheet Name keyed me in to look at the Spotlight Parameters in Document Settings - Spotlight Preferences since that's the name of the List Browser column that displays the "universal" name. I have a bunch of plug-ins and scripts that reference a Lighting Device's symbol, so I also knew that the universal name would be "Symbol Name" (which also appears in your list of parameters above, halfway down between "Brightness" and "Use Legend"). Quote Link to comment
Jesse Cogswell Posted April 3, 2021 Share Posted April 3, 2021 What is odd is that I just looked up the Developer Wiki and it directly contradicts the Script Function Reference included in the VWHelp folder by saying that "accessory index -1 is not supported by Get," so instead you pass -2 as the accessory index to get to the parent Lighting Device. Neat. Quote Link to comment
Sam Jones Posted April 3, 2021 Author Share Posted April 3, 2021 8 minutes ago, Jesse Cogswell said: I also knew that the universal name would be "Symbol Name" (which also appears in your list of parameters above, halfway down between "Brightness" and "Use Legend"). First of all I'm super glad that you found away to get the symbol name of the accessory, but the symbol name that you reference above and that I reference in the lighting device parameter list is the symbol used by the lighting device that has the accessory not the accessory. GetRField(ObjHandle, 'Lighting Device', 'Symbol Name'). Once I test it, I will use what you have figured out to reference bunch of stuff (I hope). Quote Link to comment
Jesse Cogswell Posted April 3, 2021 Share Posted April 3, 2021 That's what passing the accessory index in to the LDevice_GetParam code is for, to get to the parameters of the accessory's Lighting Device object since you can't get a handle to use the GetRField(ObjHandle, 'Lighting Device', 'Symbol Name') like you normally would. The test code that I used is below: PROCEDURE GetAccessorySymbol; VAR numAcc:LONGINT; blah:STRING; lightHd:HANDLE; BEGIN lightHd:=FSObject(ActLayer); numAcc:=LDevice_GetAccCount(lightHd,0); blah:=Concat('Lighting Device Symbol: ',LDevice_GetParamStr(lightHd,0,-2,'Symbol Name')); IF(numAcc>0) THEN blah:=Concat(blah,' | Accessory Symbol: ',LDevice_GetParamStr(lightHd,0,0,'Symbol Name')); Message(blah); END; Run(GetAccessorySymbol); Quote Link to comment
Sam Jones Posted April 3, 2021 Author Share Posted April 3, 2021 Glad you figured it out. To me, it was the a question of "Universal Name" of what since I would be passing the handle to the lighting device and not the accessory. Good for you, and thanks. Quote Link to comment
Jesse Cogswell Posted April 3, 2021 Share Posted April 3, 2021 Don't get me wrong, it truly baffles me that they didn't just add a GetLDeviceAccessory function that passes in a handle to the Lighting Device, a cell index, and an accessory index and returns a handle to the accessory and let us use the existing functions to get at its parameters. I mean, in one sense the new LDevice_GetParams allow for the same code to be used on fixtures, fixture cells, and accessories, but it does seem a bit backward and is not very well explained at all in the Function Reference. Quote Link to comment
JBenghiat Posted April 4, 2021 Share Posted April 4, 2021 For 2021, there is no separate accessory object. There are objects that represent the accessory geometry, but the data stores in a data structure attached to the lighting device. So there really is no handle to an accessory any more. The new function call looks at the data structure attached to the lighting device and retrieves data by cell index, accessory index, and field name. If you want to see which fields can hold discrete data for cells and accessories, open Spotlight preferences and look at the parameter list. The two right columns of check marks show which data can be discrete. Quote Link to comment
Sam Jones Posted April 4, 2021 Author Share Posted April 4, 2021 Josh, and perhaps Vlado and Kevin could way in, Paragraph 1 I get the concept Paragraph 2 brings up a set of questions. Question 1 Does this mean that the "LDevice_GetParamStr()" calls can be substituted for the "GetRField()" calls wherever there is a check mark in the "Multi-cell" or "Accessory" columns? Question 2 Would the following be true? "LDevice_SetParamStr(FixtureHandle, -1, -2, 'Breaker ID', '34');" and "SetRField(FixtureHandle, 'Breaker ID', '34');" are both syntactically correct and are effectively the same statements Question 3 Does an ETC Source 436 fixture have 1 cell whose index would be 0? Question 4 If so, when considering an ETC Source 436 fixture are the following statements syntactically valid and effectively equivalent? "LDevice_SetParamStr(FixtureHandle, -1, -2, 'Breaker ID', '34');" "LDevice_SetParamStr(FixtureHandle, 0, -2, 'Breaker ID', '34');" "SetRField(FixtureHandle, 'Breaker ID', '34');" Question 5 If not, why not? Question 6 What does "LDevice_ReleaseRes;" do? Question 7 (4 parts) What does the following do? LDevice_DlgResource( LayoutID :INTEGER; ControlID :INTEGER; SymbolName :STRING); what layout? what control? symbolName of what? Quote Link to comment
Jesse Cogswell Posted April 4, 2021 Share Posted April 4, 2021 @JBenghiat I see. I guess I had assumed that it was still a Lighting Device object, just embedded directly into the geometry of the PIO since the Lighting Device object can still have a Device Type of Accessory or Static Accessory. So is the Lighting Device Accessory object selectable in the Edit Accessory mode just a temporary construct that exists solely when in that mode? I see that it doesn't have any dedicated parameters listed in the Plug-in Manager. Quote Link to comment
JBenghiat Posted April 5, 2021 Share Posted April 5, 2021 12 hours ago, Sam Jones said: Question 1 Does this mean that the "LDevice_GetParamStr()" calls can be substituted for the "GetRField()" calls wherever there is a check mark in the "Multi-cell" or "Accessory" columns? Yes 12 hours ago, Sam Jones said: Question 2 Would the following be true? "LDevice_SetParamStr(FixtureHandle, -1, -2, 'Breaker ID', '34');" and "SetRField(FixtureHandle, 'Breaker ID', '34');" are both syntactically correct and are effectively the same statements Assuming you would want the breaker ID to apply to all cells in a multi-cell, yes. I’m actually not sure what would happen if you have discrete data in Beaker ID and then call SetRField. 12 hours ago, Sam Jones said: Question 3 Does an ETC Source 436 fixture have 1 cell whose index would be 0? Yes. Using a cell index of -1 and 0 is effectively the same for a one cell lighting device. 12 hours ago, Sam Jones said: Question 4 If so, when considering an ETC Source 436 fixture are the following statements syntactically valid and effectively equivalent? "LDevice_SetParamStr(FixtureHandle, -1, -2, 'Breaker ID', '34');" "LDevice_SetParamStr(FixtureHandle, 0, -2, 'Breaker ID', '34');" "SetRField(FixtureHandle, 'Breaker ID', '34');" Yes 12 hours ago, Sam Jones said: Question 6 What does "LDevice_ReleaseRes;" do? No idea, but it’s from 2019, so not relevant to the data discussion. I think it relates to your next question. 12 hours ago, Sam Jones said: Question 7 (4 parts) What does the following do? LDevice_DlgResource( LayoutID :INTEGER; ControlID :INTEGER; SymbolName :STRING); what layout? what control? symbolName of what? No idea what this does, but Layout is a dialog ID and Control is an item in the dialog. My guess is this fills a symbol resource picker with eligible lighting device symbols and selects SymbolName. 7 hours ago, Jesse Cogswell said: @JBenghiat I see. I guess I had assumed that it was still a Lighting Device object, just embedded directly into the geometry of the PIO since the Lighting Device object can still have a Device Type of Accessory or Static Accessory. So is the Lighting Device Accessory object selectable in the Edit Accessory mode just a temporary construct that exists solely when in that mode? I see that it doesn't have any dedicated parameters listed in the Plug-in Manager. Anything in the edit mode is just there for editing. I can’t remember if the accessory objects are PIOs or if the objects just have a special object info display (like text in Data Tags or Title Blocks). The edit objects get created at edit time, and then the data, location, and orientation write back to the Lighting Device on exit. Quote Link to comment
