The Hamma 15 Posted February 11 global ocnt, vcnt, mcnt ocnt = 0 vcnt = 0 mcnt = 0 def count(h4): ocnt += 1 if vs.GetTypeN(h4) == 5: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 21: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 40: mcnt += 1 def GetHandles2(h1): while h1 != []: hSEL.append(h1) if vs.GetTypeN(h1) == 92: h2 = vs.FInGroup(h1) while h2 != []: hSEL.append(h2) h2 = vs.NextObj(h2) h1 = vs.NextObj(h1) def GetHandles(h5): h2=vs.FInSymDef(h5) while h2 != []: hVP.append(h2) itParent = vs.GetTypeN(h2) # Get Parent type if itParent == 11: h3 = vs.FInGroup(h2) while h3 != []: hVP.append(h3) h3 = vs.NextObj(h3) h2 = vs.NextObj(h2) def DoIt(h5): ocnt = 0 vcnt = 0 mcnt = 0 if h5 != []: if vs.GetTypeN(h5) == 16: GetHandles(h5) for h4 in hVP: count(h4) vs.SetRecord(h5,'Obj Count') vs.SetRField(h5,'Obj Count','Obj Count',vs.Num2Str(0,ocnt)) vs.SetRField(h5,'Obj Count','Vertex Count',vs.Num2Str(0,vcnt)) vs.SetRField(h5,'Obj Count','Mesh Count',vs.Num2Str(0,mcnt)) vs.symbol(vs.GetSDName(h5),xP,yP,0) xP = xP + 300 if xP >= 5000: xP = 0 yP = yP + 300 xP =0 yP =0 if vs.GetObject('Obj Count') == []: vs.NewField('Obj Count', 'Obj Count', '0', 4, 0) vs.NewField('Obj Count', 'Vertex Count', '0', 4, 0) vs.NewField('Obj Count', 'Mesh Count', '0', 4, 0) hVP = [] hSEL = [] GetHandles2(vs.FSymDef()) for h5 in hSEL: if vs.GetTypeN(h5) == 16: DoIt(h5) What am I doing wrong? keep getting 'ocnt' referenced before assignment error. Quote Share this post Link to post
JBenghiat 355 Posted February 11 global works a bit backwards from other languages: https://www.programiz.com/python-programming/global-keyword Declare global inside the function, not out. Quote Share this post Link to post
The Hamma 15 Posted February 11 (edited) Thanks I have that working but now my counts and my symbol placements are off. My counts keep adding to the last symbols count and each symbol is being placed dead center in the drawing. They should be moving 300 to the right until 5000 is reached then move up 300 and so on. def DoIt(h5): global ocnt, vcnt, mcnt,reset ocnt = 0 vcnt = 0 mcnt = 0 reset = 0 xP = 0 yP = 0 if h5 != []: if vs.GetTypeN(h5) == 16: GetHandles(h5) reset = 0 for h4 in hVP: count(h4) reset = 0 vs.SetRecord(h5,'Obj Count') vs.SetRField(h5,'Obj Count','Obj Count',vs.Num2Str(0,ocnt)) vs.SetRField(h5,'Obj Count','Vertex Count',vs.Num2Str(0,vcnt)) vs.SetRField(h5,'Obj Count','Mesh Count',vs.Num2Str(0,mcnt)) vs.Symbol(vs.GetSDName(h5),xP,yP,0) xP = xP + 300 if xP > 5000: xP = 0 yP += 300 def count(h4): global ocnt, vcnt, mcnt,reset if reset != 1: ocnt = 0 vcnt = 0 mcct = 0 ocnt = ocnt + 1 if vs.GetTypeN(h4) == 5: vcnt = vcnt + vs.GetVertNum(h4) if vs.GetTypeN(h4) == 21: vcnt = vcnt + vs.GetVertNum(h4) if vs.GetTypeN(h4) == 40: mcnt = mcnt+ 1 reset = 1 def GetHandles2(h1): while h1 != []: hSEL.append(h1) if vs.GetTypeN(h1) == 92: h2 = vs.FInGroup(h1) while h2 != []: hSEL.append(h2) h2 = vs.NextObj(h2) h1 = vs.NextObj(h1) def GetHandles(h5): h2=vs.FInSymDef(h5) while h2 != []: hVP.append(h2) itParent = vs.GetTypeN(h2) # Get Parent type if itParent == 11: h3 = vs.FInGroup(h2) while h3 != []: hVP.append(h3) h3 = vs.NextObj(h3) h2 = vs.NextObj(h2) if vs.GetObject('Obj Count') == []: vs.NewField('Obj Count', 'Obj Count', '0', 4, 0) vs.NewField('Obj Count', 'Vertex Count', '0', 4, 0) vs.NewField('Obj Count', 'Mesh Count', '0', 4, 0) hVP = [] hSEL = [] GetHandles2(vs.FSymDef()) for h5 in hSEL: if vs.GetTypeN(h5) == 16: DoIt(h5) Edited February 11 by The Hamma Quote Share this post Link to post
The Hamma 15 Posted February 12 In def DoIt(h5): I am resetting the variables vcnt, ocnt, and mcnt to 0 but when it runs for h4 in hVP: the variables return to their state the last time def count(h4): was triggered by for h4 in hVP:. I want vcnt, ocnt, and mcnt to be 0 every time the for h4 in hVP: loop starts. Help please. I am checking the state of the variable at this point it the below script vs.SetRField(h5,'Obj Count','Obj Count',vs.Num2Str(0,ocnt)) vs.AlrtDialog(ocnt) #Displays current count but for somereason is adding the previous count to the current count vcnt = ocnt = mcnt = 0 #reset to variable to 0 vs.AlrtDialog(ocnt) #displays that variable has been reset to 0 reset = xP = yP = vcnt = ocnt = mcnt = 0 def count(h4): global vcnt, ocnt, mcnt ocnt += 1 if vs.GetTypeN(h4) == 5: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 21: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 40: mcnt += 1 def DoIt(h5): global reset,xP,yP, vcnt, ocnt, mcnt if h5 != []: if vs.GetTypeN(h5) == 16: GetHandles(h5) for h4 in hVP: count(h4) vs.SetRecord(h5,'Obj Count') vs.SetRField(h5,'Obj Count','Obj Count',vs.Num2Str(0,ocnt)) vs.AlrtDialog(ocnt) #Displays current count but for somereason is adding the previous count to the current count vcnt = ocnt = mcnt = 0 #reset to variable to 0 vs.AlrtDialog(ocnt) #displays that variable has been reset to 0 vs.SetRField(h5,'Obj Count','Vertex Count',vs.Num2Str(0,vcnt)) vs.SetRField(h5,'Obj Count','Mesh Count',vs.Num2Str(0,mcnt)) vs.Symbol(vs.GetSDName(h5),xP,yP,0) xP += 300 if xP > 5000: xP = 0 yP += 300 def GetHandles2(h1): while h1 != []: hSEL.append(h1) if vs.GetTypeN(h1) == 92: h2 = vs.FInGroup(h1) while h2 != []: hSEL.append(h2) h2 = vs.NextObj(h2) h1 = vs.NextObj(h1) def GetHandles(h5): h2=vs.FInSymDef(h5) while h2 != []: hVP.append(h2) itParent = vs.GetTypeN(h2) # Get Parent type if itParent == 11: h3 = vs.FInGroup(h2) while h3 != []: hVP.append(h3) h3 = vs.NextObj(h3) h2 = vs.NextObj(h2) if vs.GetObject('Obj Count') == []: vs.NewField('Obj Count', 'Obj Count', '0', 4, 0) vs.NewField('Obj Count', 'Vertex Count', '0', 4, 0) vs.NewField('Obj Count', 'Mesh Count', '0', 4, 0) hVP = [] hSEL = [] GetHandles2(vs.FSymDef()) for h5 in hSEL: if vs.GetTypeN(h5) == 16: DoIt(h5) Quote Share this post Link to post
JBenghiat 355 Posted February 12 I have to admit, I'm finding your script very hard to follow, which makes troubleshooting difficult. A couple general pieces of advice that may help: - The advantage of breaking out functions from the main body is to have each function perform a unitary task. To that end, structure them in terms of taking an input and generating an output and should be testable on their own. - To that end, avoid using global variables as a way to pass and retrieve values. Save them for things like constants or preferences. Your GetHandles functions should return an array of handles, which makes it clear what they do. Your count function can return a tupple of counts. That way, your main DoIt function can handle initializing, aggregating, and resetting variables and the data flow is clear. - I'm getting lost with the *2, *3, *4… variants. Rename the variables to resemble what they are, like hInObject, hSymbol, hGroup, hObject. Don't worry about repeating variable names — unless you specify "global," each function has its own scope, which is another advantage of declaring a function. Quote Share this post Link to post
JBenghiat 355 Posted February 12 I think the issue is that you just keep appending handles into hVP. As above, this is where using return values instead of globals would make this clear. 1 Quote Share this post Link to post
The Hamma 15 Posted Tuesday at 04:29 PM On 2/12/2021 at 2:27 PM, JBenghiat said: I think the issue is that you just keep appending handles into hVP. As above, this is where using return values instead of globals would make this clear. Fixed it. Thanks! ecnt = reset = xP = yP = vcnt = ocnt =scnt= mcnt= pcnt = 0 def count(h4): global vcnt, ocnt, mcnt, ecnt,scnt,pcnt ocnt += 1 if vs.GetTypeN(h4) == 5: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 21: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 25: vcnt += vs.GetVertNum(h4) if vs.GetTypeN(h4) == 40: mcnt += 1 if vs.GetTypeN(h4) == 24: ecnt += 1 if vs.GetTypeN(h4) == 84: ecnt += 1 if vs.GetTypeN(h4) == 95: ecnt += 1 if vs.GetTypeN(h4) == 34: ecnt += 1 if vs.GetTypeN(h4) == 15: scnt += 1 if vs.GetTypeN(h4) == 86: scnt += 1 def DoIt(h5): global reset,xP,yP, vcnt, ocnt, mcnt,scnt, ecnt,pcnt vs.ForEachObjectInList(count, 0, 2, vs.FInSymDef(h5)) vs.SetRecord(h5,'Obj Count') vs.SetRField(h5,'Obj Count','Obj Count',vs.Num2Str(0,ocnt)) vs.SetRField(h5,'Obj Count','Vertex Count',vs.Num2Str(0,vcnt)) vs.SetRField(h5,'Obj Count','Mesh Count',vs.Num2Str(0,mcnt)) vs.SetRField(h5,'Obj Count','3D Volume Count',vs.Num2Str(0,ecnt)) vs.SetRField(h5,'Obj Count','Nested Symbol Count',vs.Num2Str(0,scnt)) vs.SetRField(h5,'Obj Count','PIO Count',vs.Num2Str(0,pcnt)) vcnt = ocnt = mcnt = ecnt =scnt =pcnt = 0 #reset to variable to 0 vs.Symbol(vs.GetSDName(h5),xP,yP,0) xP += 300 if xP > 5000: xP = 0 yP += 300 if vs.GetObject('Obj Count') == []: vs.NewField('Obj Count', 'Obj Count', '0', 4, 0) vs.NewField('Obj Count', 'Vertex Count', '0', 4, 0) vs.NewField('Obj Count', 'Mesh Count', '0', 4, 0) vs.NewField('Obj Count', '3D Volume Count', '0', 4, 0) vs.NewField('Obj Count', 'Nested Symbol Count', '0', 4, 0) vs.NewField('Obj Count', 'PIO Count', '0', 4, 0) hSEL = [] h1 =vs.FSymDef() while h1 != []: hSEL.append(h1) if vs.GetTypeN(h1) == 92: h2 = vs.FInGroup(h1) while h2 != []: hSEL.append(h2) h2 = vs.NextObj(h2) h1 = vs.NextObj(h1) for h in hSEL: if vs.GetTypeN(h) == 16: DoIt(h) Quote Share this post Link to post
