Rob Glisson Posted May 9, 2001 Share Posted May 9, 2001 Like earlier comments, I have arrowheads misplaced slightly when printing. I have mac OS, VA 9.0 and am plotting to a HP 450. What's going on? Quote Link to comment
LGA Posted May 15, 2001 Share Posted May 15, 2001 Hello, We are having the same problem with the arrowheads stopping short of the item we are pointing to, both with our notes and our dimensions. We are working on a G3, with OS 9.1, 256 mb RAM, using VWA 9. We are printing to an Epson 1520. What is the cause of this, and is there a fix brewing? We are trying to finish two projects and these arrowhead issues are an obstacle. Could someone give a status report on this, especially on whether there is a repair revision forthcoming? Thank you. Laurie quote: Originally posted by Rob Glisson: Like earlier comments, I have arrowheads misplaced slightly when printing. I have mac OS, VA 9.0 and am plotting to a HP 450. What's going on? Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted May 15, 2001 Vectorworks, Inc Employee Share Posted May 15, 2001 This is a known problem with non-Postscript printers. A fix is forthcoming shortly. Quote Link to comment
LGA Posted May 16, 2001 Share Posted May 16, 2001 Hello, Thank you very much for the update. We will look forward to the fix. Laurie quote: Originally posted by Robert Anderson: This is a known problem with non-Postscript printers. A fix is forthcoming shortly. Quote Link to comment
feyerly Posted July 10, 2001 Share Posted July 10, 2001 Also, we are experiencing this problem. This ought to be considered a very serious problem considering the only reason an arrowhead exists is to point at something.... and if it doesn't? The arrowhead issue should jump to the top of the bug list and a patch should come out now. Quote Link to comment
Carl Burns Posted July 10, 2001 Share Posted July 10, 2001 Possibly related?...About a year ago using VW 8.xx / W95, I updated the driver for my HP 4M printer and the VW leader lines became disoriented, rotated from the desired position. I returned to the slightly older version of the driver and everything printed properly again. Carl Quote Link to comment
CipesDesign Posted July 11, 2001 Share Posted July 11, 2001 Here's the workaround: Stretch the arrowhead farther so that its BASE is where you want the point to be. It will then print accurately. Stupid, eh? PLC Quote Link to comment
DWHarper Posted August 2, 2001 Share Posted August 2, 2001 Any word on whether this arrowhead bug problem has been corrected? Quote Link to comment
CipesDesign Posted August 2, 2001 Share Posted August 2, 2001 This is fixed in 9.0.1 PLC, Mac G4/450 HP DJ230 Quote Link to comment
