bob cleaver Posted December 9, 2020 Share Posted December 9, 2020 (edited) When publishing multi sheets into a single PDF, many times the sheets do not maintain the class selections. This is especially true with irrigation classes - We will have classes for viewports and worksheets selected and saved, and when publishing the drawing set, the classes randomly turn off. The workaround is to check each sheet and publish them individually and then combine them into a single PDF. We could be missing a step in the save and publish actions - We assume we are not alone ?? Edited December 9, 2020 by bob cleaver Quote Link to comment
loretta.at.large Posted December 10, 2020 Share Posted December 10, 2020 I usually have that problem when publishing something that has a Worksheet with thumbnail or symbol images built into it. Also, a problem with objects that are on top of a Sheet Layer (as opposed to in a Viewport). Quote Link to comment
