Micha095 Posted November 6, 2020 Share Posted November 6, 2020 Hello everybody Can anyone tell me if there is a Marionette that can create a plan list for me? If so, where can I download it? Thanks in advance Micha Quote Link to comment
Boh Posted November 6, 2020 Share Posted November 6, 2020 Is a plan list the same asa drawing list. If so you can use a data base worksheet to do that. But maybe you specifically want to me se marionette? Quote Link to comment
Micha095 Posted November 8, 2020 Author Share Posted November 8, 2020 Thank you for the answer. I was hoping to be able to insert a marionette into the plans and then, by executing it, get a list of the layouts with the numbers etc. in a table. But if this is possible with this database worksheet, I will try it like this. Quote Link to comment
Boh Posted November 8, 2020 Share Posted November 8, 2020 Attached is a data base worksheet that lists all Title Block Borders, their sheet number, sheet name, and current revision. You can also produce a static (non-data base) worksheet from the Tools>Reports>Create Sheet List command. I prefer teh data base worksheet. Cheers Sheet List Worksheet.vwx 1 Quote Link to comment
Micha095 Posted November 9, 2020 Author Share Posted November 9, 2020 perfect. thanks a lot Quote Link to comment
