Kal Posted October 19, 2020 Share Posted October 19, 2020 I am new to VW and I am drawing a floorplan. I was moving the walls by dragging them or adding dimensions and putting in a new dimension to move them. Now all of a sudden I cannot do either. Does anyone know what could cause this? Quote Link to comment
Pat Stanford Posted October 19, 2020 Share Posted October 19, 2020 In the Mode bar you have the No Interactive Scaling option (first item. The double diagonal arrow with the Red Circle with diagonal (Don't) line.). Select either the second (Single Object Interactive Scaling Mode) or the third (Multiple Object Interactive Scaling) and you should be able to make the adjustments you need. 1 Quote Link to comment
Kal Posted October 20, 2020 Author Share Posted October 20, 2020 Thanks Pat, this worked after I closed and reopened the program today. The weird thing is I was trying these different modes before and they were not working. Quote Link to comment
P Retondo Posted October 20, 2020 Share Posted October 20, 2020 Pat's comment may come into play, but I also find that if there are too many joins to a wall, it cannot be dragged. I have to remove one or more joins, then it will work. It seems like the program could be improved so that it doesn't get stuck like this. 2 Quote Link to comment
