burch Posted April 3, 2006 Share Posted April 3, 2006 This is the second time I have encountered this problem. Vectorworks-(Architect,renderworks) 12.01 refuses to open and says it has encountered a problem and needs to shut down. Error reports always point to Quicktime problem. The last time this happened I had to re load V12. This time I will have to re load 12 and then update to 12.01 again! I've got work to do!!! Any thoughts out there as to what is causing this problem ? This is very annoying.(Using PC - 2GB Ram ) Quote Link to comment
Christiaan Posted April 4, 2006 Share Posted April 4, 2006 What version of Quicktime are you running? Quote Link to comment
burch Posted April 4, 2006 Author Share Posted April 4, 2006 Quicktime version is 7.02. Quote Link to comment
Guest Posted April 4, 2006 Share Posted April 4, 2006 burch, There's another discussion regarding this problem. We are currently working on determining the cause of the problem. If you can please send your contact inforamtion to me, as well as your OS and VW serial number, we can add you to our list of people experiencing this problem. We will likely be in touch soon after to gather additional information. Quote Link to comment
SteveK Posted April 4, 2006 Share Posted April 4, 2006 burch, Do you have another computer running VW12? If so, you might try backing up the Workspaces folder on the problem computer and then copy the Workspaces folder from the working computer. It may not work for you, but it seems to have fixed my problem. Steve Quote Link to comment
burch Posted April 5, 2006 Author Share Posted April 5, 2006 Stevek, Your'e the winner! thank you so much for your input. It worked for me also ! I'm wondering how you ever figured that out, since the error messages pointed to a quicktime problem. Anyway thanks again for your help. Burch Quote Link to comment
