- 0
Vectorworks 2020 | Data Visualization | Image Fill showing uncorrectly
Asked by
Tbai
Asked by
Tbai
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
Hiya,
I was looking for an alternative solution for viewport class override to quickly turn black/white plans to coloured on sheet layers across different files following a 'preset' palatte. I'm aware of you can group and copy the viewports through, but if classes, fill colours or line types named differently, you won't get the same result by eyedropping the viewports.
I just switched to 2020 and gave Data Visualization a try since Vectorworks 2020 got quite some update on it. If I just set my data visualization preset to replace classes's Fill to Solid colours, it works great (except for you can't change opacity and shade setting, and anything set to none in classes won't get replaced/ applied), but it seems struggling get the image fills right using data visualization preset (on both design layers and sheet layers).
If any of the above doesn't make sense, please see my testing file attached.
Thanks for helping
14102020 -Data Visualization Example.vwx
Edited by TbaiShare this post
