for my convenience (or bad luck) I did a part of my drawing in Screen Plane mode, I had half drawn in a 2D view (Layer Plane) but I needed to add objects to a Cavalier 45 front perspective. To draw this, I worked better to do it in Screen Plane, the problem is that now I try to make a viewport or export it to PDF and the objects are not visible or come out flattened in the Layer Plane,
Is there any way to make these objects appear on the paper? or at least a way to export them as they are? Exporting "Current view" does not work, Image file doesn't work either.
I attached an image of the viewport and an image of the drawing I'm expecting to get.
frxnska
Hello,
Thank you all in advance, stay safe!
1 answer to this question
