Viper x Posted September 28, 2004 Share Posted September 28, 2004 When I place plants using 10.5 in the drawing the plant symbol is placing fine but the plant tags main pointer line is way, way outside the drawing area, so far out I can not even see it in the drawing window, these are the tags that you activate under "tag display" in the object info. I believe there is a setting to control the length of the main line, is this the case and if so where is it accessed please ? I have read responses about the "shoulder" length of the tag but not this main line length. Thanks Viper x [ 09-28-2004, 08:02 AM: Message edited by: Viper x ] Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted September 28, 2004 Vectorworks, Inc Employee Share Posted September 28, 2004 This is a known bug. When you see this occurring, you should reset the origin to the center of the page (print area). Quote Link to comment
Viper x Posted September 28, 2004 Author Share Posted September 28, 2004 I went to page > set origin > set origin to centre of page >placed some new plants and there has been no change, tag is still 3 house blocks away. Was this the correct procedure to reset the origin ? Thanks Viper x Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted September 28, 2004 Vectorworks, Inc Employee Share Posted September 28, 2004 Please redefine the plant you're using. Just go to the Edit Plant Catalog, click "edit" for the plant of interest, then OK, then try again. Quote Link to comment
Viper x Posted September 28, 2004 Author Share Posted September 28, 2004 Tried that for an existing plant symbol I am using but it had no effect. But it did work for a new plant I defined as a test. Any other ideas on how to fix all the already defined plant symbols please ? Thanks Viper x Quote Link to comment
