Hi all.
This viewport is rendered background=unshaded polygon. Has anyone experienced the unwanted diagonal lines, indicated in green, attched? Seem to be associated with a re-shaped wall....any comments welcome. Rendering in opengl solves the problem. (I used unshaded polygon because it renders two extrudes semi-transparent, the ones showing existing gables of this extended house.)
200511 GA Tech 1.pdf
Just a thought, if object was non-coplanar you could get this effect.
Also I had a drawing a few years back where I'd imported some linework and vw decided it would put an (onscreen invisible) line thru a polygon that appeared to be flat and the line printed. Took ages to find the object and explode it and remove problem. I know nothing of rendering in vw tho; so YMMV.
Thank you! I will have a further look.
Yes, I once imported an object from a manufacturer which had an embedded problem....
...I really appreciate you responding.
I will post any fix.
