I downloaded a contour shape file from my regional governments data base however when i import it, each contour (1m intervals) is actually separated closer to 100 or 1000 meters apart on the Z axis. Iv had this issue in the past with dwg files in autocad/sketchup but have never found a solution.
Is there something i can do to set the z values to equidistant spacing?
owen1991!
1 answer to this question
