James Chipman Posted March 22, 2020 Share Posted March 22, 2020 Hello all, Does anyone know how to expand the number of blocks on a din rail terminal? I have to draw a 150 port din rail, and the only way I have found is to draw 3 48 block units then go into each separate block and change the name. TB.02.1-48 creates fine, but I can't create anything bigger. I can create TB.02.1-48 again under that, but then have to go into each block and re-label it. conductor Also, anyone have a suggestion on documenting a 3 conductor wire into a DIN terminal? I would like to show all three wires on the block. As well, any good ideas on how to make an internal jumper on the output side of a block? ie. jump TB.02.27 to TB.02.29 on the output side? Thanks for any assistance Chippy Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted March 25, 2020 Vectorworks, Inc Employee Share Posted March 25, 2020 Hi James At the moment the number of blocks is not adjustable, but I will make sure we take care of that ASAP. and let you know. Thanks for reaching out. Thank you also for showing me the detail workflow you need for these DIN blocks. This has been added to my plans and I will create a solution for this. Conrad Quote Link to comment
