Hi all,
Adding a Big +1 here.
I regularly create drawings with multi-line cables of up to 32 +/-/G sets for large audio installations. A Canare MR202-32AT cable might come out of a terminal block in a rack and run to another terminal block in a rack in a different location. With the terminal block device, I can use a single cable to represent one of the 32 sets, but if that runs to another rack, I have to connect 32 terminal blocks individually on each end. As well, it does not allow me to represent the MR202-32AT as a single cable, but only as 32 separate 25awg cable sets.
I know this is a big ask, but it would be nice to identify the cable type, and select how many lines it has. Then somehow have a break-out/break-in point at the line termination.
As an example, a 32 set cable that runs to a terminal block in a rack is labelled xxxx. When you click to connect it to a device, it recognizes the number of lines in the cable, and then asks for 32 different connections. Labelling each of those connections in turn xxxx/1, xxxx/2, xxxx/3, etc.
I could create this as a separate device, but I don't want to confuse any of the installers.
I've attached a small example of the things I convert from our designers. They use CAD, but we use VWX, so I re-draw them so it can be viewed on one drawing for the end user.
Any sort of cable type selection, or as mentioned previously in this thread, a .txt file that can be edited would be a great start.
Comments?
Thanks
James Chipman
