ericjhberg
Get Rectangle - Inaccurate
Is there a marionette node that better pulls the true length, width, and reference point of a rotated rectangle? The basic one basically pull the bounding box dimensions of a rotated rectangle and not true length, width, or point of reference.
@ericjhberg
the marionette node  "get rectangle" don't work?
for more information you can use "convert to Poly", then with "get Vertex" you get all the corners
Greatings M.G.
Thanks for the suggestion @m.graf; however, I don't want to convert to Poly because I want the functionality of a rectangle...including the length and width parameters.
Right now my suggestion is to use the Get Width and Get Height in the Object Info category for those values, I'm looking into the best method for the referenced point while rotated since the naming of those points when rotated may not be accurate.
I've also submitted a bug to update the Get Rectangle node once I've gotten a good solution.
Thanks @Marissa Farrell. For the task I am attempting the corner points are definitely the most valuable...but the length and width will be important too. I think I'll have to wait for a better Get Rectangle node before going further with my task.
You could still take some of the recommendation from @m.graf and duplicate the rectangle, convert to poly, retrieve points, then delete. You'd just need to sort values to find the corner you're looking for.
