MHBrown
VW lights cannot be placed nor seen
I'm using VW2018 with SP6 on a MacBook Pro running OS Sierra. All of a sudden, I cannot place any lights in my files. I click the light tool as I've done thousands of times before, click in my drawing and nothing places. I opened a file that I knew had dozens of lights and none of the lights were there. The renderings created from that model were all over the place as far as lighting: some dark, some super bright. Mostly dark. Has anyone had this experience? If so, what did you do to get it back? I sorta need lights in my renderings.
Thanks,
Mike
It sounds like the Class your lights are assigned to may be turned off.
Thank you for responding, but I don't think it is something simple like that. I wish it were! I opened a blank VW file, which has only two classes as you know: dimension and None. I cannot place a light in that file, either.
Mike
I have VW Architect, so I'm not sure what the Spotlight Workspace is. Is there a "show lights" or "hide lights" hot key I may have pressed my mistake?
Mike
Mike
 Very odd -
There's no Show/Hide lights apart from Class / Layer visibilities
You can control whether light objects are visible via the VW Preferences>Display but this isn't what you're asking.
You can switch Lights on/off individually or via the Visualization Palette
Have you tried a restart?
I got my wish for something simple. Somehow, someway, the VW Preferences had "Never" for show lights. I must have created a hot key for that and somehow accidentally clicked that combination. I totally forgot about that. Thanks for suggesting that I look at that. All the lights have come back, but it's odd that even a new document had that setting. I suppose that's because it was a VW Pref and not a Document pref. Thanks for solving the mystery: human error as it often is.
Mike
@MHBrown, another tip when working with lights, if you render in openGL, only 8 of the actual light objects will show any "glow."  It's a limitation of openGL.  All the lights should show properly in other render modes.  I usually select "Only show in Wireframe" for my lights.
Wes
Of course, all the lights are back, but now I'm getting the viewports rendering as solid white as has been reported here before. I think I have to restart for that. I hope these problems are resolved in VW2020 which I will be installing soon.
Mike
Great - glad you got it sorted.
