MPJDesign Posted July 20, 2005 Share Posted July 20, 2005 When I add or import a symbol or an object(s)from another vectorworks drawing, by copy/cut and pasting, the object retains the same class name and then I have to go into sheet set-up to allow that class to be visible the next time I want to run that sheet view macro... If the object is going to be visible in multiple sheets set ups, I have to edit the view, then update the class visibility to do my thing, then hit ok...fine I got that. But to keep editing other sheet views, I have to repeat the whole process again starting from the beginning. Wouldn't it be nice to remain in the edit sheet view set-up until I have fixed my visibility task through-out multiple views? OR a better dialogue box that can update across saved sheet views? Just my wish to improve the ease of use of this program. or Is there a better way to do this? Quote Link to comment
islandmon Posted July 21, 2005 Share Posted July 21, 2005 The problem appears to be that the saved sheets database needs to update with each changed entry. Opening multi saved sheet containers solves the problem, but is not possible. Quote Link to comment
Travis Posted July 21, 2005 Share Posted July 21, 2005 You can update Save Views from the Classes "control" dialog. Highlight the Class you want to modify, then click on the Save Views button at the bottom. This brings up a list of all Saved Views that you can then set the class visibility for. I just wish there was a similar function for multiple Viewports. Good luck, Quote Link to comment
