katebjohnson Posted June 17, 2005 Share Posted June 17, 2005 I am working on a plan, which has several different angles. I would like to rotate the page (layer) while I am drawings, so I can draw with right angles in one area and then rotate again to work on the next section and finally rotate all back to the original starting point so it aligns with the site plan. Is there any way other than rotating the plan with a 2D rotate? I tried rotate grid, but it did not rotate my drawing. Thanks Quote Link to comment
Delmer Posted June 17, 2005 Share Posted June 17, 2005 The short answer is no. The rotate grid will give you I and J coordinates that you can tab to along the top of the screen. You can also set your Constrain Angle Snap to the angle you are drawing at. I am sure you will get more suggestions. - This has been asked about by others and would be a welcome addition to the saved views function. [ 06-17-2005, 11:43 AM: Message edited by: Delmer ] Quote Link to comment
shorter Posted June 20, 2005 Share Posted June 20, 2005 A third party plug-in is available from a company called VectorBits. I don't know how reliable it is, however. Quote Link to comment
