AntBSD
2014 Insufficient memory please help
I am running VW 2014 on Windows 10 with 16gig Ram memory. When I want to export a drawing (very small in size - less than 1meg) then it gives me a message that I require more memory?!?! (see attached image) Please help. How can I resolve this issue?
1 answer to this question
Do you have other programs running as well when this happens, or is there perhaps a large amount of data copied and still in the clipboard? If it is a 3D rendering you are trying to export this could require a bit more than you might expect depending on output settings (have run into that in the past).
There is the possibility that VW has not released unused memory properly and nibbling away on available memory. Are you able to export after restarting VW or even the computer if restarting VW does not solve the issue?
