milezee
VW not Using GPU
Hello  Forum, my PC doesn't seem to be using the GPU at all when rendering, the task manager shows the CPU being maxed out, around 99% and the GPU usage is about 1%. Is there something we need to change on our PC's ?? tia
Check the following document. Partially it tells how CPU and GPU are used in VW.
On your Windows PC, check the NVidia settings to make extra sure your good GPU (NVidia) is used and not the one of your motherboard.
@Nicolas Goutte thanks for the input. It seems Rendering in VW uses the CPU, and the GPU is fully used when rotating, panning, zooming etc, is this correct ??
As far as I understand, Renderworks uses the CPU, while 2D and OpenGL use the GPU.
  • Like 3
yes it seems that is the way it works, thanks for clearing this up, cheers 🍻
