KroVex Posted July 3, 2019 Share Posted July 3, 2019 Hi All I have a question about the Layer Order, when i use "Layer with Type" or "Layer". I have textfields wich i manipulate with some "String replacer" before it reverse the list* and create Layers. The Order of the Layers are in the correct range then. But if i only add some new Nodes, which have nothing to do with the create layer section, the Order will change. I have no idea what affects the layer order. It seems to me completely arbitrary. *I need the reverse node - without it, the order mess is way larger. How can I determine and influence the order? Greetings KroVex Quote Link to comment
Marionette Maven Marissa Farrell Posted July 3, 2019 Marionette Maven Share Posted July 3, 2019 I would suggest using an Ordered List node to assign the order of the creation. There's no real way to determine the order of inputs to a single port if many wires enter it; the Ordered List node will ensure that the values are passed in the order you've specified. 1 Quote Link to comment
