lisagravy
Image Props Location
I'm trying to export a model with crosshair style image prop 3D trees from the vectorworks library.
Is there a way of packaging the file so that the image prop is also sent? I've had a look on my system and can't really find any of the library images stored to send separately?
Thanks,
Lisa
Hi Lisa
The images that make up the image props are found within Renderworks textures. There will be a corresponding texture for each Image Prop. You can right-click on the texture and choose to Extract Image. This should give you what you need.
