Elevation Linework Poor Quality!?
CraigC
Guest Wes Gardner
I assume you made the elevation with the "Create Section Viewport" command (or the Clip Cube)?  You can also bump the sheet layer's DPI up if you need to...usually the default is OK for line work.
